Previous Topic: Select Targets for DeploymentNext Topic: Configure the Agent
Specify User Credentials
Use the User Credentials dialog to specify user credentials for the discovered computer that you have selected as a target computer for the deployment payload. Specified user credentials are required before deployment is possible.
To specify user credentials
  1. Enter a valid user name for the target computer.
  2. Enter the password of the specified user.
    Note: This field can be left blank if the target computer has a blank password (not advised).
  3. (Optional) Select the Use these credentials on all computers requiring credentials option to specify that the user credentials be used for all of the selected target computers.
  4. Click OK.
Note: The credentials are not tested at this point; invalid credentials will only be detected when the deployment is active.
