A deployment job specifies how you install packages. The deployment job options let you specify the packages to install and the computers on which to install them—by domain, range of addresses, name, directory, target credentials file (*.tc), or query. It also lets you specify non-default options to be passed down to the installation commands used to install the packages, for example, installing agents into non-default folders on the target computers.
The deployment job scans the target computers to determine if deployment is possible. The following are typical responses from the target computers:
