The Deployment node provides access to the Deployment Management component, which is part of the Client Automation suite of applications. This component provides the ability to deploy software to many target systems without the need to log on manually to each computer. Deployment enables you to transfer an installation image, run the installation process, and monitor the results of the installation on each of the targets.
Deployment places the initial piece of software on remote targets and does not need any Client Automation software to be installed on the target system.
You install Deployment as part of the Client Automation installation. Deployment has the following distinct components:
Note: See the "dmsweep--DSM Deployment Command Line Interface" chapter in the Client Automation CLI Reference Guide.
You can also set common configuration policies for component deployment within the Client Automation infrastructure. For more information, see the Configuration Policy section of the DSM Explorer Help.
Notes:
