The DSM Explorer › Control Panel › Deployment › Deployment Jobs › How to Deploy Components
The Infrastructure Deployment Wizard lets you deploy Client Automation components to your environment using a deployment job that sweeps your network. It is a task-oriented wizard that guides you through the process of creating a job and specifying the settings for deploying one or more agents or a scalability server to target computers.
The basic steps for creating a deployment job are as follows:
- Specify the deployment job name and type.
- Select a DSM software package to deploy.
- Specify deployment target criteria.
- Scan the target computers to make sure that the software packages can be deployed on the targets.
- Select the scanned computers on which to install the software package.
- Specify additional agent configuration and installation details for the deployment payload when it is delivered.
- Review the specified settings and deploy the software package.
