The Summary wizard page displays the settings that you have selected for the deployment job.
To complete the deployment process
(Optional) If you want to start the deployment job at a later time, clear this check box, and the finalized job will be placed into the Suspended state after Step 2. Then use the Activate context menu command when you are finally ready to start the deployment job.
The new deployment job is added to the Deployment Job Status pane where it can be monitored and controlled.
