A deployment payload is the data that is being distributed to the target machine. The Deployment Payload wizard page lists the Client Automation software packages available from the deployment manager. Use this page to select a single package to deploy.
To select a deployment payload
This option lets you transfer packages from an intermediate location and to specify the scalability server to be used at that location. If you select this option, follow all steps.
If you do not select this option, packages are transferred directly from the deployment manager. In this case, go directly to Step 5.
The scalability server is configured, and you are returned to the Deployment Payload page.
The packages available for the selected operating system are listed.
