The Select Field dialog lets you select the database fields that you want to include in your query. Depending on the query to be created, various arguments may apply.
This dialog contains the following list view, group box, and fields:
Lists the fields, such as Classification, Relationship, System Identification, Agent Component, Agent Restrictions, and so on relevant to the argument type that you have selected in the Query Designer dialog.
Displays the following fields in the Arguments group box.
Displays the field that you have selected in the Fields list.
Specifies the operator valid for the selected field name. The operators listed in this drop-down depend on the field type. For example, the text fields have the operators such as Like, In, and =.
Specifies the value you want to query. You can specify wildcard expressions for text fields using the Like operators. By default, a maximum of 100 values are displayed in this drop-down list. If you want to see more values, select <more..> from the list to open the Search Possible Values dialog.
