The Search Possible Values dialog displays all the possible values for the selected field in the Select Field dialog.
This dialog has the following fields:
Specifies the filter condition. You can select the operator in this field and specify the criteria in the adjacent field. You can perform a wildcard search on the text fields and use the relational operators on numeric fields.
Defines the number of records shown in the Value List list box.
Default: 100
Lists the possible values after applying the filter condition and result limit for the selected field in the Select Field dialog. You can double-click any item to add it to the drop-down on the Select Field dialog.
