Note: Available categories and options may vary depending on the products and components installed.
The Software Usage table, INFOHIS, stores information about the offline software usage.
This table contains the following columns:
Includes the Action ID.
Example:
MHISAC_PREVENTED = 0
MHISAC_NORMAL_NORMAL = 1
MHISAC_WARNING_NORMAL = 2
MHISAC_NORMAL_ABNORMAL = 3
MHISAC_WARNING_ABNORMAL = 4
MHISAC_QUEUED_GRANTED = 5 (The number of minutes the user was in queue for this application.)
MHISAC_NORMAL_INACTIVITY = 6, (Started normal, Inactivity stop.)
MHISAC_WARNING_INACTIVITY = 7 (Started with warning, Inactivity stop.)
Indicates whether the software usage entry was collected by the engine or by importing online data.
Includes the UUID of the domain instance.
Includes the date when the application was last stopped
Includes the time when application was last stopped
Includes the total of ENDTIME, seconds since 1970.1.1.
Includes the type of object.
Example: ca_discovered_hardware=1, ca_discovered_user=2.
Object UUID. Foreign key to either ca_discovered_hardware or ca_discovered_user depending on object_type.
Includes the start date when application was launched
Includes the start time when application was launched
Includes the start date and time
Includes the software definition UUID of the monitored application.
Includes the software domain UUID of the monitored application.
