Previous Topic: Select Target DialogNext Topic: Add Advanced Argument Dialog
Query Designer Dialog
The Query Designer tool lets you create or modify a query. Using this tool, you can query information about computer and users, jobs, policies, software, inventory and external directories. You can also query the database fields and create advanced queries. The left pane of the Query Designer dialog lists these items: Insert Argument with all the available arguments, Boolean Operators, Remove Argument, a preview function and a view SQL statement option.
Note: Although the user can now be registered with the Asset Collector, as can an associated trust and origin, the Query Designer does not allow user queries to be created with trust level and origin as conditions.
The right pane of the Query Designer dialog shows the arguments as you add them to the new query.
Insert Argument
General Information
Lists discovered hardware and software properties.
Inventory
Lists discovered inventory.
Software
Queries Software Packages, Discovered Software, Software Usage and File Contents.
Jobs
Queries Asset Jobs and Collect Tasks.
Policies
Queries the Query Based and Event Based policies.
Directory Query
Browses an organizational asset to query any member, or select any user to query its direct reports.
Note: To create a directory query, a directory object must be available under Control Panel, Directory Integration, Configured Directories folder.
Advanced Argument
Queries the asset management tables in the database for a specific query. Select the arguments in the Add Advanced Argument dialog.
Link Query
Opens the Select Query dialog where you can link an existing query and add the query as an argument.
Boolean Operators
Specifies the following operators that Query Designer uses to test for the validity of some condition and return a Boolean value of TRUE or FALSE.
AND
Combines two Boolean expressions and returns TRUE when both of the expressions are TRUE.
OR
Combines two conditions and returns TRUE when either expression is TRUE. When more than one logical operator is used in a statement, OR operators are evaluated after AND operators.
NOT
Reverses the value of any Boolean expression.
Changes the order of evaluation.
Remove Argument
Removes the argument selected on the right pane from the Query Designer.
Preview
Runs the query and opens the Query Preview dialog to display the query result.
View SQL
Shows the SQL Query statement in the SQL View dialog. You cannot modify the SQL statement on this dialog.
