You can use the following overall procedure, along with the standard software delivery deployment methods, to deploy a virtual application package update.
To deploy a virtual application software package update
Notes:
Vendor infrastructure software must be installed on the target servers and clients. You can complete this step using your own local procedures or you can use the infrastructure package templates provided with Client Automation. See the following descriptions for more information: Preparing a Target Computer for Deployment of a Microsoft App-V Virtual Application and Preparing a Target Computer for Deployment of a VMware ThinApp Virtual Application.
You may need to reboot the target server after installing the Microsoft System Center Application Virtualization Streaming Server. The Streaming Server set-up process initiates this reboot.
Note: Staging and Standalone packages only are needed for virtual application updates. The Streaming package contains only links to the Staging package and the virtual application. These links do not need to be updated.
The virtual application software package updates are installed.
