After the virtual application package that you created with the Virtual Application Package Registration Wizard is included in the Software Package Library, you can then deploy it and manage it using standard software delivery methods. Virtual application packages can be registered on the enterprise (EP) management tier or the domain management tier. A virtual application package should not be registered on both the EP and domain management tiers. If you register a virtual application package on the EP management tier, it can then be distributed to the domain management tiers and lower levels.
Virtual application package deployment goes through the following general stages:
Note: You may need to reboot the target server after installing the Microsoft System Center Application Virtualization Streaming Server. The Streaming Server set-up process initiates this reboot.
Note: If the target computer roams to a new scalability server, the new server must have the Staging package installed as well. For more information on roaming, see the Software Delivery Administration Guide.
Note: For more information about virtual application deployment, see the Software Delivery Administration Guide.
