You can monitor and control the active deployment jobs using the Control Panel, Infrastructure Deployment, Deployment Job Status node and its corresponding pane.
To display details about the computers involved with a deployment job, select the job in the Deployment Job Status pane. If the deployment job has failed on a specific machine you can determine why and then reattempt the deployment. A pie chart in the Information pane of this view provides an overview of the deployment progress.
You can suspend, cancel, or resume a deployment job. You can also discard a job that is complete or canceled.
