Previous Topic: New Summary Objects OptionNext Topic: Multiple Output Formats
Customized Reports
You can customize reports with the appearance and information you want by using the Windows Client Output Report wizard and the View and Output Definition wizard.
Note: The Customize Reports Wizard in the Web Client provides an output report feature you can use to create and manage user-view object data output reports and schedules for output reports. For more information, see the CA Vantage Web Client Guide.
This wizard allows you to define:
Windows Client View and Output Definition wizard
To start the Output Report wizard in the Windows Client
  1. Click the object in the Object Tree view to open the object view.
  2. Click File, Output Report. Or click one of the following icons from the object window toolbar:
    The Output Report wizard opens.
To start the View and Output Definition wizard in the Windows Client
  1. Click the object in the Object Tree view.
    The object view opens.
  2. Click the Definitions icon (Definitions icon) from the toolbar of the object view.
    The View and Output Definition wizard opens.
Example: Define fields to be displayed in a Storage Groups report
You can create a report based on the Storage Groups object that contains information on the SG Name, Type, % Allo, Vol Cnt, Capacity Bytes, Allocated Bytes and Free Bytes. You can then sort the report by descending % Allo.
The following example shows how you would define this report in the Windows Client View and Output Definition>View>Fields dialog.
This is a screen shot example of the Windows Client View and Output Wizard Fields page showing the sort in descending order option.
Note: For more information about the View and Output Definition dialog, click the Help icon in the View and Output Definition dialog.
