Introducing CA GMI › Standard CA GMI Features
CA GMI user-interfaces provide a rich set of standard features for working with your products and related object data. These features include the following:
- Simultaneous connection to several z/OS hosts, with separate views for each host, or all hosts consolidated into a single view
- Table views of all data, customizable with the ease of point‑and‑click
- Graphical views of any numeric data, easily customized, with a wide range of two‑dimensional and three‑dimensional features
- Filtering and sorting on any field
- Summary Totals and Statistics (aggregate functions such as total, average, minimum, and maximum)
- Scaling (KB, MB, GB, and so on) and color coding features
- Drill‑down feature to zoom to related object data
- Wizards for simple or complex summaries (Summary Objects)
Note: Currently, you can create and manage Summary Objects using only the Windows Client. You can view Summary Objects using both the Windows Client and the Web Client.
- Reporting features for customized and printed reports
- Multiple output formats, including:
- Schedulers for producing and sending report output on a regular basis
- JCL management (edit, model, drag and drop, substitute, submit, and schedule)
Note: Currently, JCL management is only available in the Windows Client.
The following sections provide examples of some of the standard features of the Windows Client:
