Previous Topic: Open Zoom Option (Drill-Down Feature)Next Topic: Customized Reports
New Summary Objects Option
The Windows Client Summary Designer helps you create new summary objects from any source object. You select the method for defining the summary groups and select the fields to include in the summary object. The summary object includes summary groups from a source object table, and then provides statistics about all the object rows that fall into each summary group. The statistics include counts, maximum values, minimum values, average values, and totals. These statistics are provided for each group of records and for all the records.
You can start the Windows Client Summary Designer two ways, from the object pop-up menu or from the Object view Menu Bar.
Note: Currently, you cannot create or manage Summary Objects using the Web Client. You can view Summary Objects using the Web Client.
To start the Windows Client Summary Designer from the object pop-up menu
  1. Right-click on the object in the Object Tree view.
    The Object pop-up menu appears.
  2. Select New Summary Object in the Object pop-up menu.
    The Summary Designer appears.
To start the Summary Designer from the object view Menu Bar
  1. Click the object in the Object Tree view.
    The object view appears.
  2. Select View, then New Summary Object from the object view Menu Bar.
The following is a sample of the Summary Designer.
This is a screen shot example of the Windows Client Summary Object Designer.
Note: For more information about how to use the Summary Designer to create a new Summary Object click the Help icon in the Summary Designer dialog, or see the chapter "Working with Generalized Summary Objects" in the CA Vantage User Guide.
