Previous Topic: Color Code OptionNext Topic: New Summary Objects Option
Open Zoom Option (Drill-Down Feature)
The Windows Client Open Zoom feature provides you with a list of objects that have related information. You can select an object from the Zoom list dialog to view the related information.
Note: The Web Client provides a Zoom feature on the Object toolbar. For more information, see the CA Vantage Web Client Guide.
To zoom to related objects in the Windows Client
  1. Select a row in the object Table View.
    The selected row is highlighted.
  2. Click the Open Zoom icon (Open Zoom icon).
    The Zoom list dialog appears, listing related objects.
  3. Click an object in the Zoom list.
    Object information in the object selected for that item appears.
The following sample illustrates a zoom from a particular Storage Group in the Storage Groups object to the same Storage Group in the Storage Groups Volumes object.
This is a screen shot example of the Windows Client Open Zoom results.
