The TSS control option is protected by a special prompt for the MSCA's previous password. A record of the event is recorded to provide an audit trail.
This command is designed mainly for entry from the system console:
F TSS,TSS
However, it may also be entered as a command:
TSS MODIFY(TSS)
or from PARMLIB:
TSS
An operator console prompt requests the MSCA previous password:
After successful entry of this password, a second prompt allows the entry of any CA Top Secret command:
The command is entered as a console response, including the initial TSS keyword.
This example enters a TSS command function at the z/OS console:
F TSS,TSS
The system displays:
TSS9691A ENTER TSS COMMAND PASSWORD
R xx,password
If this password is correct, the system displays:
TSS9272A ENTER <TSS COMMAND> OR <END>
R xx,TSS ADDTO(USERO1) DSNAME(ABC.DEF)
Note: If this command is entered from anywhere else but the z/OS console, a prompt at the console awaits a response.
