Manage Archive Library Instances › Configuring Archiving for Interaction Request Forms › Accept or Override Policy at Orchestrator Level
You can override the setting for archiving completed Interaction Request Form objects at the Orchestrator level.
- Click the Configuration tab.
- On the Configuration Browser pane, right-click the target Environment and select Lock.
- Click the target Orchestrator.
- Click the Modules tab, right-click a process control module, and select Edit.
- On the Properties tab, clear the Inherit settings check box.
- In the Time to Keep Completed User Interaction field, type a new value.
- Click Apply, then click Save.
- On the Configuration Browser pane, right-click the target Environment and select Unlock.
Copyright © 2014 CA.
