Previous Topic: Accept or Override Policy at Orchestrator LevelNext Topic: Purge Archived Instances
View Archived Instances
Use the following automation objects to view the archived instances in the Operations tab:
Process Instances
Displays the archived instances of various processes.
Process Watch
Displays the archived instances of the Orchestrator and the process.
Add an Orchestrator, process, or both in a process watch document to retrieve all archived instances.
Global Schedule
Displays all archived instances of all active schedules. Open a global schedule and select the Archived Instance option to display only archived instances of all active schedules.
  1. Click the Operations tab.
  2. From the Links menu on the Operations tab, select the automation objects for which to view archived instances.
  3. Select the Archived option button in the upper right of the Operations tab.
    CA Process Automation retrieves the archived Instances from the database.
  4. Select a Start and End Time filter to view the archived instances for the specified date range.
