If the Orchestrators you are upgrading are installed on 32-bit hosts, see TEC596124 for guidance on migrating to 64-bit hosts.
Before you upgrade CA Process Automation, the value calculation of the Minimum Number of Finished (Completed, Failed, Aborted) Instances field includes the Failed Instances. After you upgrade CA Process Automation, the Field label changes to Minimum Number of Finished (Completed, Aborted) Instances and the value calculation does not include the Failed Instances.
