Install the Domain Orchestrator › Test Your Processes with Simplified Communication
After you have configured agents to use simplified communication, test your processes again.
- Start a process with operators that run on agent touchpoints or on remote hosts through proxy touchpoints. Verify that the process instance completes successfully.
- When you are satisfied that agents are working as expected with simplified communications, resume all of your normal processing.
Copyright © 2014 CA.
