Upgrade to the Current Release › Upgrade a Nonclustered Orchestrator
After you upgrade the Domain Orchestrator by invoking a script distributed on the media, you can upgrade other Orchestrators from the CA Process Automation UI.
- Log in to the host on with the Orchestrator to upgrade.
- Browse to CA Process Automation and log in with administrator credentials.
- Click the Configuration tab and select the Installation palette.
- Click Install in the Install Orchestrator section to begin the upgrade.
- Select a language and click OK.
The Welcome to the CA Process Automation Third-Party Installer Setup wizard page appears.
- On the Licensing agreement page, select the option to accept the agreement, and then click Next.
- On the Select Destination Directory page, navigate to the directory that you used for the previous release. For example, in Windows, the following are defaults, depending on the source release.
C:\program files\ca\itpam
C:\program files\ca\pam
- Click Next to Prerequisites for CA Process Automation Installation.
- Specify JDBC jars for installation in one of the following ways:
- To use the same JDBC jars as the Domain Orchestrator, leave the Use Domain check box selected and click Next.
- To use different JDBC jars than the Domain Orchestrator uses, clear the Use Domain check box and do the following:
- Click Add Files.
- Select the database type.
- Click Browse and navigate to the JDBC JAR file for the selected server type.
- Click Next.
- Click Next to confirm, and then click Finish to advance to the CA Process Automation installer.
- Click Next on the Welcome page
- Select the option to accept the license agreement and click Next.
- When the Java Home Directory page appears, browse to the location of the upgraded JDK and then click Next.
- Click Next to proceed through the following installation wizard pages:
- Domain URL
- Single Sign-on and Load Balancer configuration page
- Company Name
- Enter the certificate password, and click Next.
Important! This entry must match the certificate password that was entered when the Domain Orchestrator was upgraded.
- Click Next to accept the previous configuration on following installation wizard pages:
- Start Menu Folder preferences and click Next.
- General Properties
- Scripts temporary directory
- PowerShell run policy
- Repository database settings for this Orchestrator
- Runtime database settings
- Reporting database settings
- Click Finish.
- When processing completes, start the Orchestrator service on the upgraded nonclustered Orchestrator.
Note: See Start Orchestrators for operating system-specific details.
More Information:
Example: Upgrade a Non-clustered Orchestrator from 4.1 SP01 to Release 4.2 on Windows
Copyright © 2014 CA.
