Previous Topic: Switch Load Balancers from Apache to NGINXNext Topic: Configure Agents to Use Simplified Communication
Update F5 Pools, iRule Definition, and Configuration
To use simplified communication, modify the F5 configuration.
  1. Create two F5 pools for each CA Process Automation cluster.
  2. Replace your current iRule with The iRule Definition.
  3. Configure F5 to use simplified communication with HTTPS.
