Install an Additional Orchestrator › Post-Installation Tasks for an Orchestrator
Perform the following post-installation tasks as needed.
- To configure an Apache load balancer to use secure communication through SSL, take the following steps:
- Navigate to the following folder:
apache_install_dir\conf\extra\
- Open the following file:
httpd-ssl.conf
- Add the following lines inside the <VirtualHost> </VirtualHost> tags at the end of the file:
SSLOptions +StdEnvVars +ExportCertData
JkMount /* loadbalancer
Note: To configure a load balancer to use basic communication, comment out the previous statement.
- Save the file. Close the file.
- Restart the Apache HTTP Server.
- Configure ports.
- Configure firewalls for bi-directional communication.
- If you installed the Domain Orchestrator on a server with the HP-UX operating system, perform additional configuration steps on HP-UX.
- (Windows only) Start the Orchestrator service.
The Orchestrator registers itself with the Domain Orchestrator.
- Verify the installation of the additional Orchestrator.
- Browse to CA Process Automation and log in.
- Click the Configuration tab.
- Click the Orchestrators node in the Configuration Browser palette.
- View the new Orchestrator in this list.
