After you install the Domain Orchestrator, you can add Orchestrators on other hosts. Each new environment needs at least one Orchestrator, but can have more than one Orchestrator. Multiple Orchestrators permit segmentation. New Orchestrators inherit CA EEM information from the Domain Orchestrator.
Before you use the following procedure, complete the prerequisites to installing an Orchestrator. For example, verify that you have a JDK installed.
Use the following process to install an Orchestrator or to upgrade an existing Orchestrator.
If you use the Firefox web browser, open it with Java Web Start Launcher (the default).
If necessary, install the required certificate as instructed. The application downloads. The Language Selection dialog may appear in the system tray.
The Welcome to the CA Process Automation Third-Party Installer Setup wizard page appears.
The Installing JBoss page shows the progress of installing jboss-5.1.
Specifies whether you are using CA SiteMinder with SSO, where the default is cleared. Selecting this option enables these fields:
Specifies whether to install this Orchestrator so it can cluster.
Selected
Indicates that a load balancer is configured for this Orchestrator.
Cleared
Indicates that no load balancer is configured for this Orchestrator.
Specifies the name of this node. Because this Orchestrator is the first node in this cluster, specify node1.
Note: For nodes other than node1 (for example, node 2), see:
Specifies the public host name for the Apache server, NGINX server, or the F5 server. For example:
loadbalancerhost.mycompany.com
If Support Secure Communication is cleared, this field specifies the HTTP port for the Public Host.
Default
80
If Support Secure Communication is selected, this field specifies the HTTPS port for the Public Host.
Default
443
Specifies whether the Public Host uses HTTPS for secure communication.
Selected
The Public Host uses HTTPS for secure communication.
Cleared
The Public Host does not use HTTPS for secure communication; instead, it uses HTTP for basic communication.
If this certificate password is lost or forgotten, you must reinstall all Orchestrators in the CA Process Automation system and specify this certificate password, beginning with the Domain Orchestrator.
Specifies the FQDN of this Orchestrator.
Specifies the name that the Configuration Browser displays for this Orchestrator.
