After you install an additional Orchestrator, you can extend its capacity and provide failover capability by adding a cluster node. If any node fails, other node takes the control. You can use an interactive or unattended installation to install cluster nodes.
This section contains the following topics:
Prerequisites to Installing a Cluster Node for an Orchestrator
Install a Cluster Node for an Orchestrator
Synchronize Time for a Cluster Node
