Rather than configuring cluster nodes after they are present in CA Process Automation, you configure the nodes that you expect to add to any clustered Orchestrator up front.
The Node List displays the following details for each network node that has been defined to F5: the status, the IP address, the partition, and the host name.
The New Node page appears.
Specifies the IP address of the new node.
Specifies the host name of the associated IP address.
Specifies the health monitor for this node. If it is not configured, select None.
Default: Node Default
Specifies a weighted value to assign to the node. If the nodes that belong to the same cluster all have the same capacity, enter 1 as the Ratio value for each node.
Specifies the maximum number of connections that this node can handle.
The added node is displayed in the Node List.
