You can create an F5 Virtual Server.
The Virtual Servers List displays the following details for each Virtual Server: the status, the name, the partition, the destination IP address, the service port, the type, and an Edit link for Resources.
The New Virtual Server page appears.
Specifies the name of the virtual server, for example, PAMLB.
Specifies Host for a single IP address.
Specifies the IP address of the virtual server, for example, 10.130.5.149.
Specifies the associated port for the virtual server, for example, 80 for HTTP, 443 to HTTPS.
Specifies whether the virtual server is available for load balancing. Specify Enabled.
Specifies the type of virtual server. Standard is a virtual server that directs all traffic to the pool you defined as the default load balancing pool.
Default: Standard
Specifies the HTTP profile for managing HTTP traffic. Select http.
Specifies the iRules to enable for this virtual server. Select the iRules script that you created for the clustered Orchestrator.
Include the iRule that you created for the default pool.
Specifies the name of the pool that the virtual server routes traffic to. Specify the CA Process Automation pool as the default pool.
Specifies the persistence profile for this virtual server. For example, source_addr.
Specifies the persistence profile that this virtual server uses when the default persistence profile cannot be used. For example, dest_addr.
