An iRule routes operator requests that target the touchpoint of a clustered Orchestrator. F5 creates a URL from this information and uses that URL as the touchpoint destination. To create an F5 iRule for CA Process Automation, copy the provided iRule definition into the Description text box. Then, set the values for
Note: An iRule identifies one Orchestrator cluster node for a request that targets the touchpoint of a clustered Orchestrator. The decision is based on the URL.
The iRules List is empty if you are setting up iRules for the first time. The iRules List displays the following details for each iRule: the iRule name and the partition.
The New iRule page appears.
Specifies the iRule name.
Specifies the iRule definition. Copy the text from The iRule Definition into this text box.
Note: The programming language that is used for iRules is Tcl, Tool Command Language.
Specifies whether to extend the text area of the Definition text box to its maximum size.
Selected - Extends text area to its maximum size.
Cleared - Presents text area in a size that is less than maximum.
Specifies whether to wrap the text to fit in the Definition text box rather than display a horizontal scroll bar.
Selected - Wraps text that extends beyond the viewable portion of the Definition text box, excluding a horizontal scroll.
Cleared - Presents text as entered, with a horizontal scroll bar if needed.
The iRule you enter appears in the iRule List.
