Before you install any Orchestrator, verify that the Java Development Kit (JDK) prerequisites are met. Use the following command:
Java -version
The preceding example shows a valid Java version for Windows.
Note: For other details, see Platform Support and Requirements for CA Process Automation Components. If default Java version is different, change the default Java version on the shell where you will start the CA Process Automation installer.
