If the default version is different, change the default Java version on the shell where you will start the CA Process Automation installation.
set JAVA_HOME=<home_directory_of_jdk (not_bin)> set PATH=%JAVA_HOME%\bin;%PATH%
export JAVA_HOME=<home_directory_of_jdk (not_bin)> export PATH=$JAVA_HOME/bin:$PATH
.\ Domain_Installer_windows.bat
./ Domain_Installer_unix.sh
The installer first starts the third-party installer and then starts the Domain Orchestrator installer.
