Install the Domain Orchestrator › Prerequisites to Installing the Domain Orchestrator › Database Prerequisites › Database Owner Privileges
When you start CA Process Automation for the first time or when you apply a patch, the application adjusts the database or schema structure.
To adjust the structure, CA Process Automation requires the following database privileges at a minimum:
- The right to access metadata (to determine the structure)
- The right to CAD (create/alter/drop) tables, indexes, views, constraints, and sequences in the database.
- Read or Write rights on all its tables
CA Process Automation requires the following privileges for its tables during runtime:
- Select
- Insert
- Update
- Delete
