The following table summarizes the platforms that CA Process Automation components support.
Note: The listed operating system and software support can change over time. For the latest information about version support, see “Compatibilities” on support.ca.com.
Make sure your operating system has the latest Windows service packs or Linux updates installed.
CA Process Automation Component |
Supported Operating Systems |
Required Software |
Other Requirements |
Orchestrator |
Microsoft Windows Server 2003 x64 Microsoft Windows Server 2003 R2 x64 Microsoft Windows Server 2008 x64 Microsoft Windows Server 2008 R2 x64 Microsoft Windows Server 2012 x64 Solaris SPARC 10 Solaris 11 Red Hat Enterprise Linux 5 x64, 6 x64 CentOS Linux 6 x64 |
Java Development Kit (JDK) 1.7 x64
Agent |
Microsoft Windows Server 2003 x86/x64, 2003 R2 x86/x64, 2008 x86/x64, 2008 R2 x86/64, 2012 x86/x64 SUSE Linux Enterprise Server 10 x64, 11 x32, 11 x64 Solaris SPARC 9, 10 Solaris 10 x86, 11 Red Hat Enterprise Linux 5 x64, 6 x86, 6 x64 CentOS Linux 6 x64 AIX 6.1, 7.1 HP-UX 11i V3 (Itanium) |
One of the following Java Runtime Environment (JRE) releases supported by the operating system.
For HP-UX, minimum HP JRE level is 1.6.0.04. Important! Do not use Java 6 Runtime Environment updates 27 (1.6.0_27) through 29 (1.6.0_29). An issue with those versions affects applications including CA Process Automation that use JDBC to connect to Microsoft SQL Server. The SDN bug database lists this issue as bug 7105007. Java 1.6 update 45 is the latest Java 6 version that CA Process Automation agents support. |
Database Server |
See the vendor documentation for supported operating systems. |
One of the following relational databases:
See Database Server Prerequisites for detailed requirements. For Oracle, we recommend 11.1.0.7 or 11.2.0.2 or higher. |
Directory Server |
See CA Embedded Entitlements Manager (CA EEM) documentation. |
CA Embedded Entitlements Manager (CA EEM) r8.4 SP4 or CA EEM r12.0 -r12.51 |
Browser-based UI |
N/A |
One of the following browsers:
JavaScript enabled Adobe Flash Player |
