Running, Testing, and Debugging Processes › Run Processes Interactively › Start a Process as Suspended from the Library
You can start an instance of a process in a suspended state to achieve any of the following objectives:
- Insert breakpoints.
- Set parameters.
- Make other changes before the process runs.
- Monitor or control the execution of a process.
- Debug the sequence of steps in the process.
- Click the Library tab.
- Click Orchestrator and select the appropriate Orchestrator:environment.
- Navigate to the folder that contains the process to start in suspended state.
- Take one of the following actions:
- Right-click the process and select Start Suspended.
- Select the process and select Start Suspended from the More Actions drop-down list on the toolbar.
The Monitor Process Instance prompt opens.
- Click Yes to open the Designer tab with the debug toolbar. You can begin working with the suspended instance immediately.
- Click No to load the process into the Operations tab. The Designer tab does not open. You can later navigate to the instance in the Process Watch palette in the Operations tab. To continue, right-click that instance and select Start Suspended.
More information:
Debug a Process
