Running, Testing, and Debugging Processes › Debug a Process
Debug a Process
When you open an instance of a process, the Process Designer helps you monitor the status and debug a process. Debug buttons are available on the Process Designer toolbar. When processing is suspended, you can edit the process and change parameter values in operators.
A process can be suspended in several ways:
- When an instance is started in a suspended state.
- When you click the Suspend Process button.
- When a process ends and you click the Switch Process Status on Completion button on the Process Designer toolbar. The process is suspended but the status appears as Blocked.
- When there are no valid operators left on any branch of a running process. The process is suspended but the status appears as Blocked.
