Running, Testing, and Debugging Processes › Run Processes Interactively › Start a Process from the Library
You can start a process from the Library tab. Starting a process immediately lets you perform a task in a production environment.
- Click the Library tab.
- Click Orchestrator and select the appropriate Orchestrator:environment combination.
- Navigate to the folder that contains the process to start.
- Take one of the following actions:
- Right-click the process and select Start Process.
- Select the process and select Start Process from the More Actions drop-down list on the toolbar.
The Monitor Process Instance prompt opens.
- Click Yes to open a new window to monitor the running instance of the process.
- Click No to run an instance of the process. The process is not displayed.
The process starts immediately.
