This chapter describes how to run, test, and debug processes interactively during development. The same methods can be used to run processes in a production environment.
When you want to run a process, you can initiate it using any of the following methods:
The Workflow module on an orchestrator runs processes. When you start a process on an orchestrator, the Workflow module creates and runs a copy of the process object in the orchestrator automation library. This running copy is an instance of the process. The Workflow module creates a separate instance of a process each time you start a process (or another process or application starts a process).
You can open, view, and work with an instance of a process while it is running or after it finishes. Changes made to an instance of a process affect only that instance and do not affect the original process object stored in an automation library.
When a process starts, it connects to the correct agent or orchestrator modules on managed network computers. A process performs its designated operator functionality, tests conditions, and exercises dependencies. When error conditions arise, a process performs corrective actions and notifies operators and administrators when necessary. An administrator can use the Application Monitor to monitor running processes and to perform corrective actions.
This section contains the following topics:
Simulate Processing of Operators
