Administer Agents › Configure the Contents of a Selected Agent › Customize Operator Category for a Selected Agent
All environments, Orchestrators, and agents inherit settings that you configured on the Modules tab for the Domain. Administrators can edit the configuration at lower levels of the Domain hierarchy. Administrators can also enable categories of operators on any agent and can edit the configurations as necessary.
- Click the Configuration tab.
- Expand agents, right-click the agent to customize, then select Lock.
- Click the Modules tab.
- Select Enabled from the Enable/Disable drop-down list for the operator category to edit.
- Right-click the same category, then select Edit.
- Change the property settings of the selected category for the selected agent. For more information, see the following Domain-level field descriptions:
- Click Save and click OK on the verification message.
- Right-click the locked agent, then select Unlock.
