Administer Operator Categories and Custom Operator Groups › Configuring Operator Categories › Configure Utilities
Configure Utilities
You can configure default settings for the Invoke Java operator in the Utilities category only if the operator runs on an agent. Otherwise, this operator category requires no configuration. The Invoke Java operator is not permitted to run on Orchestrators.
- Click the Configuration tab, select Domain, and click Lock.
- Click the Modules tab, right-click Utilities, and select Edit.
The Default Invoke Java Operator Properties tab opens
- Select the Use Strict Java Mode check box to enforce typed variable declarations, method arguments, and return types in the main method code at runtime.
- Click Add Parameter
and define the external JAR files as appropriate.
- To remove a selected JAR file, select an item from the External Jars list, and then click Delete.
- Complete the remaining fields on the Utilities window as appropriate.
- Click Save and Close.
- Click Save.
- Select Domain and click Unlock.
More information:
Category Configuration and Operator Inheritance
