Administer Agents › Configure the Contents of a Selected Agent › Disable an Operator Category on a Selected Agent
From the Modules tab for a selected agent, you can disable one or more operator categories for that agent.
- Click the Configuration tab and expand Agents on the Configuration Browser palette.
- Select the agent to configure and click Lock.
- Click the Modules tab.
- Select an operator category for which Enable/Disable is set for Enable or Inherit from Environment.
- Select Disable from the Enable/Disable drop-down list.
- Click Save.
- Click Unlock.
The product disables the selected operator category on the selected agent.
More information:
Enable or Disable an Operator Category
Operator Categories and Where Operators Run
Override Settings Inherited by a Category of Operators
Configure Network Utilities
Configure Web Services
Configure File Management
Configure Command Execution: Default Telnet Properties
