Administer Operator Categories and Custom Operator Groups › Configuring Operator Categories › Configure Catalyst Defaults
You can configure the Catalyst defaults by completing the following tabs:
- Default Catalyst Properties
- Default Catalyst Security
- Default Catalyst Claims
- Default Catalyst Password Claims
Note: The password values are encrypted.
- Click the Configuration tab, select Domain, and click Lock.
- Click the Modules tab, right-click Catalyst, and select Edit.
The Default Catalyst Properties tab opens.
- Configure the default Catalyst properties.
- Type the appropriate default URL in the UCF Broker URL field. The associated operator inherits this setting. Examples of URLs for basic and secure communication follow:
http://hostname:7000/ucf/BrokerService
https://hostname:7443/ucf/BrokerService
- Type the appropriate name in the Product property configuration file name field. This file is used to customize the properties that the generic Create operator shows.
- Click the Default Catalyst Security tab and type the default Catalyst user ID and password.
- Click the Default Catalyst Claims tab and complete the configuration.
- Click Add Parameter and enter the first claim name with its value.
- Repeat this step for each default claim.
- Use the up and down arrows to sequence the claims as needed.
- Click the Default Catalyst Password Claims tab and complete the configuration.
- Repeat this step for each default password claim.
- Click Save and Close.
- Click Save.
- Select Domain and click Unlock.
More information:
Override Settings Inherited by a Category of Operators
Category Configuration and Operator Inheritance
About Catalyst
