Administer Orchestrators › Configure the Contents of an Orchestrator Host › View Orchestrator Security Settings
Most of the Security tab settings are created during the Domain Orchestrator installation process. You cannot change any of these settings through the UI. You can change these settings by reinstalling the Domain Orchestrator.
The Inherit check box applies only to CA EEM Cache Update Interval (in seconds). You can shorten the update interval when you want CA Process Automation to receive changes that you make in CA EEM more quickly.
- Click the Configuration tab.
- In the Configuration Browser palette, expand Orchestrators.
- Select an Orchestrator. You can view security settings on the Security tab.
- To update the settings:
- Click Lock.
- Clear the Inherit check box.
- Update the EEM Cache Update Interval (in seconds) value.
- Click Save.
- Click Unlock.
More information:
View or Reset Security Settings for a Selected Environment
Configure CA EEM Security Settings for the Domain
