You can install as many Orchestrators as are necessary. The first installation creates the Domain Orchestrator. After the Domain Orchestrator is running, you can install additional Orchestrators from the Installation palette on the Configuration tab.
Orchestrators are the "engines" of CA Process Automation; they process the content that is designed with CA Process Automation. All processes run on Orchestrators, which manage and run automation objects. Orchestrators direct agents to perform required actions as part of the process.
This section contains the following topics:
Configure the Contents of an Orchestrator Touchpoint
Update the Hierarchy of an Orchestrator Touchpoint
Configure the Contents of an Orchestrator Host
Maintain the Orchestrator Host
