Most of the Security tab settings are created during installation or upgrade of the Domain Orchestrator. You can change these read-only settings only by reinstalling the Domain Orchestrator.
Each environment inherits the settings that you establish during the Domain Orchestrator installation. If you clear the Inherit check box, you can update the CA EEM Cache Update Interval (in seconds). When you shorten the update interval, CA Process Automation reflects changes that you make in CA EEM more quickly.
The Security tab opens.
Note: If you reduced the CA EEM Cache Update Interval, consider suppressing the CA Process Automation permissions cache. See Control Caches of CA EEM Updates.
