Most of the CA EEM security settings are established during the Domain Orchestrator installation. One CA EEM instance manages security for the CA Process Automation Domain. Therefore, these same settings apply to all environments in the Domain and to all Orchestrators within all environments. You can change the read-only settings by reinstalling the Domain Orchestrator.
The Security tab displays.
This value expresses the interval (in seconds) between CA EEM cache updates. The CA EEM cache contains current CA Process Automation user account, group, and policy settings. When CA EEM updates the cache, it sends CA Process Automation the contents of the refreshed cache. The default value, which optimizes the system performance, is 1800 seconds (30 minutes).
This value is set only if CA EEM is configured to use an external user store and Multiple Microsoft Active Directory Domains is selected. CA Process Automation users referenced in the AD domain specified here can log in with an unadorned user name. CA Process Automation users referenced in other selected AD domains are authenticated with their principal names (that is, domain_name\user_name). The same difference in naming conventions extends to how user identities are referenced in the main pane of the Library tab.
If you reduced the CA EEM Cache Update Interval, consider suppressing the CA Process Automation permissions cache. See Control Caches of CA EEM Updates.
