Previous Topic: Process Test Control FilesNext Topic: Process Test Inventory Records
Process Test Library Code
If you are familiar with processing test Library Codes, perform the following steps. If you are not familiar with processing test Library Codes, for more information see the Reference Guide.
To process test library codes
  1. Add a Library Code using the test PDS libraries created.
    Use the PDS member existence exit (APAS0200) and a model specification of INCLUDE APJMPDS.
  2. Require approvals and enable inventory assignment and Retrieve when you set up the Library Code.
    Use a Retrieve model specification of INCLUDE APJCPDS; INCLUDE APJCMSGS.
    Note: Add a STEPLIB statement to model APJCMSGS to point to the CA PanAPT loadlib, CAI.CABYLOAD.
