Previous Topic: Verify Online SystemNext Topic: Process Test Library Code
Process Test Control Files
If you are familiar with processing test control files, perform the following steps. If not, for more information see the Reference Guide.
To process test control files
  1. Update the system information record in the control file with the system ID, company name, date format, date separator, and time separator of your choice.
    You can revise CA PanAPT system information at any time to add other system information such as Approval Category Descriptions and Retrieve Options.
  2. Add a user to CA PanAPT.
    You can have several user IDs available to test authorization requirements.
