Previous Topic: Process Test Library CodeNext Topic: Create a Move Request
Process Test Inventory Records
If you are familiar with processing test Inventory Records, perform the following steps. If you are not familiar with processing test Inventory Records, for more information, see the Reference Guide.
To process test inventory records
  1. Add an Inventory Record for one of the members of the Library Code you created in when processing test library code.
  2. Assign the Inventory Record to yourself.
  3. Retrieve the member and make sure it is copied to your test library.
