Previous Topic: Edit Members in the CABYCLS0Next Topic: Process Test Control Files
Verify Online System
To access the online portion of the system
  1. Log on to TSO using your newly created logon procedure and select ISPF.
    The ISPF/PDF Primary Option Menu panel should now show the CA PanAPT option.
  2. Select the CA PanAPT option and press Enter.
    The CA PanAPT Main Menu panel displays. CA PanAPT has now been activated.
  3. Press PF3 to exit CA PanAPT.
  4. From the ISPF/PDF Primary Option Menu, type TSO APT on the command line and press Enter.
    This is an alternate method of entering CA PanAPT and can be performed from any ISPF/PDF command line.
See the Reference Guide for further information.
